6. Edition W40K
  • Das ist zwar schonmal schön, aber ich werd wohl nicht die 60€ für das Regelbuch ausgeben, lieber noch auf die neue Box mit kleinem Regelbuch warten. Nehm mal stark an das das auch kommen wird.
    Ist da schon irgendnen Termin in Aussicht?
  • September
  • Mal bissel was neues:
    via Warseer's Darnok and Whitehat
    First Whitehat:
    -Random Charges are 2D6 pick the highest (unless going through Difficult Terrain where its 3D6 and you drop the highest.) Move through cover I believe adds an extra D6
    -Vehicles are WS0 if stationary, and WS1 if they move, no matter how far they go.
    -Vehicles go the same distance in the movement phase (I believe 6" and fire everything regardless if fast or not) but in the shooting phase can make an extra move (apparently some kept forgetting what vehicles moved to fast to fire...
    -Vehicles cannot contest (unsure if scoring units in transports can
    -6 Missions and 3 deployment types (2 of the deployments are the same as current, Spearhead & Pitched Battle.)
    -Troops are the only ones that can score (including of course 'scoring units')
    -5+ Cover save for most things (ruins are 4+).
    -Allies rules are in, but its meant to be for team games (ie separate force org chart, distrusted ally rules similar to Fantasy)
    -Percentages are *not* in
    -Wound Allocation is closest to furthest.
    -Dueling is similar to challenges in fantasy but contrary to earlier rumors, they don't replace Combat res, just add to sides. A IC can challenge another IC in the same combat even if not in base to base. If the defending IC refuses, he simply cannot attack that turn, if he does he counts as being in b2b and no one else can hurt him apart from the attacking IC. I'm guessing this is to offset the Wound Allocation rules
    -Preferred Enemy is including shooting and you may reroll wound rolls of a 1 (either shooting or combat)
    -Rapid Fire weapons may now can shoot at long range while moving. restriction on assaulting after rapid firing remains.
    -Jump Infantry get a free strike at I10 when they charge into combat
    -Psychic Power Decks using a dice system similar to Fantasy.
    -Flyers are in.
    -FNP drops to 5+ Save.
    and Darnok:
    -AP are on ccw but he says power weapons are ap 2, not 3.
    -When you charge it's double your move, infantry move 6, bikes 8 cav 7 etc.
    -It's move assault then shooting now!
    -Fnp is 5+. Master crafted ccw give you a 5+ invuln save
    -When you shoot you roll to hit depending on the speed of your target. Fast vehicles you always need a 6.
    -A unit can't claim a object while inside a vehicle.
    -There's new kinds of instance death. If your say strengh 8 vs a space marine captain toughness 4
    you only do 2 wounds! Strengh (9?) or more would do 3 wounds & kill him.
    -In kill point missions you get kill points based on what the units points cost, so for example a
    landraider would be worth 5 kill points & a unit of marines 3pts.
  • Weiterhin: Mit vorsicht geniessen!
  • Danke Shurion, hätten wir eh gemacht...
    Gibt soviel Gerüchte, Fakten haben wir erst mit dem Buch auf dem Tisch...
    Wobei es wohl sicher scheint, dass sie (ähnlich wie bei Fantasy) das gesamte System stark umkrempeln...
    Freue mich natürlich besonders, da ich mit Blood Angels und vor allem Necrons 2 recht aktuelle Codizes habe die schon auf die aktuelle Edition zugeschnitten sind und teilweise wohl besser werden...
  • Fände ich gar nicht schlecht, wenn die Jungs mit dem gleichen Eifer an die 6. Edi ran gegangen wären, wie bei der 8. von Warhammer Fantasy. Der Aufschrei im Vorfeld war zwar recht groß und eigentlich wollte keiner die neue Edi spielen aber ich finde sie sehr gut gelungen. Und das obwohl mich als Bretonen-Spieler einige der härtesten Änderungen getroffen haben. Wie auch immer... Ich denke die haben ihre Erfahrungen gemacht und werden die in 40K einfließen lassen. Ich bin absolut gespannt.
  • Externer Inhalt i47.servimg.com
    ohne Worte
    Dämonen Fantasy Chaoskrieger
    Je zw 1500 und 6000 Pkt
  • Ich behaupte frech, dass es eine Fälschung ist. Normalerweise müsste dort unter dem Warhammer 40000 Logo noch sowas wie eine Bezeichnung sein. Black Templars oder Regelbuch...
    Unten scheint zwar auch noch was zu stehen, aber dies ist einfach nicht Fett genug.
    "Mit meiner Kraft zerstöre ich,
    Mit meinem Schwert töte ich,
    Mit meiner Macht beherrsche ich,
    Mit meinem Blut korrumpiere ich."
    +++ Erster Vers des Schwurs der Bruderschaft des Blutes. +++
  • und es sieht nach hardcover aus....seitwann gibt es hardcover im 40k? noch gar nicht...
    Gruss Qasim
    "Es ist der Wert der Überzeugung, der den Erfolg ausmacht. Nicht die Anzahl der Anhänger." (Remus Lupin)
    Besuch meinen Let's Play Kanal auf Youtube! (momentan noch in Bearbeitung :P) Game Wars
  • Das Hauptregelwerk war schon immer Hardcover und ich denke mal mit der 6. Edi wird das auch für die Codizes eingeführt...
  • ...naja, Warhammer Fantasy hat seit der 7. Edition ein Hardcover Regelwerk, 40k auch erst seit der letzten Edition.
    Alles andere waren bestenfalls limitierte Ausgaben...
    Bin mal gespannt ob die das wie bei Warhammer Fantasy machen- finde die Hardcovers eigentlich ganz gut, nur schade dass die dann eventuell Codizes, welche schon auf die neue Editiopn ausgelegt wurden, noch nciht so gemacht haben
  • Mal ein paar Preise:
    Complete Barcode Short Sales Code Product Name Contents WD Promotion Advance Order D Release R/T Release USD CAD
    Warhammer 40,000: Rulebook (English) 440pp Hardback Book July 23-Jun-12 30-Jun-12 30-Jun-12 $74.25 $90.00
    Warhammer 40,000 Munitorum Templates 3 x Templates July 23-Jun-12 30-Jun-12 30-Jun-12 $19.75 $23.75
    Warhammer 40,000 Munitorum Tape Measure Servo Skull Tape Measure July 23-Jun-12 30-Jun-12 30-Jun-12 $16.50 $19.75
    Warhammer 40,000: Psychic Powers (English) 32 Cards, Leaflet, Box July 23-Jun-12 30-Jun-12 30-Jun-12 $13.25 $16.00
    Tanglewire TBC July - 7-Jul-12 7-Jul-12 $10.00 $13.75
    Warhammer 40,000 Munitorum Dice 12 Dice, 6 Dice Holders, Tin July 21-Jul-12 28-Jul-12 28-Jul-12 $16.50 $19.75
    Warhammer 40,000 Munitorum Battlefield Objectives 12 Dice, 6 Dice Holders, Tin July 21-Jul-12 28-Jul-12 28-Jul-12 $16.50 $19.75
    Warhammer 40,000 Munitorum Vehicle Markers 12 Dice, 6 Dice Holders, Tin July 21-Jul-12 28-Jul-12 28-Jul-12 $16.50 $19.75
    Orikan the Diviner 1 Fig Clampack July 14-Jul-12 21-Jul-12 21-Jul-12 $19.25 $25.00
    Anrakyr the Traveller 1 Fig Clampack July 14-Jul-12 21-Jul-12 21-Jul-12 $19.25 $25.00
    Warhammer 40,000: Gamers' Edition (English) Rulebook, Dice Set, Satchel July 23-Jun-12 30-Jun-12 - $123.75 $149.00
    Warhammer 40,000: Collectors' Edition Rulebook (English) Rulebook July 23-Jun-12 30-Jun-12 - $132.00 $158.50
    Servitors with Multi-melta 2 Fig Clampack July 14-Jul-12 21-Jul-12 - $16.50 $19.75
    Servitors with Plasma Cannon 2 Fig Clampack July 14-Jul-12 21-Jul-12 - $16.50 $19.75
    Broadside Battlesuit Upgrade Pack 10 Piece Pack July 14-Jul-12 21-Jul-12 - $14.75 $17.75
    Commander Shadowsun 1 Fig Box July 14-Jul-12 21-Jul-12 - $40.00 $48.50
    Crisis Battlesuit Commander Upgrade Pack 9 Piece Pack July 14-Jul-12 21-Jul-12 - $13.25 $16.00
    Tau Empire Pathfinders 3 Fig Clampack July 14-Jul-12 21-Jul-12 - $19.75 $23.75
    Tau EmpirYe Kroot Hounds 4 Fig Box July 14-Jul-12 21-Jul-12 - $24.75 $29.75
    Tau Empire Pathfinders with Rail Rifles 3 Fig Clampack July 14-Jul-12 21-Jul-12 - $19.75 $23.75
    Tau Empire Vespid Stingwings 5 Fig Box July 14-Jul-12 21-Jul-12 - $45.00 $55.00
    Tau Empire Krootox 1 Fig Clampack July 14-Jul-12 21-Jul-12 - $24.75 $29.75
    Tau Empire Shield Drone Upgrade Pack 8 Piece Set July 14-Jul-12 21-Jul-12 - $13.25 $16.00
    Tau Empire XV15 Stealth Armour 3 Fig Clampack July 14-Jul-12 21-Jul-12 - $19.75 $23.75
    Aun'Va, Master of the Undying Spirit 3 Fig Box July 14-Jul-12 21-Jul-12 - $40.00 $48.50
    Tau Empire XV15 Shas'Ui 2 Fig Clampack July 14-Jul-12 21-Jul-12 - $19.75 $23.75
    Tau Ethereal 1 Fig Clampack July 14-Jul-12 21-Jul-12 - $16.00 $19.75
    Ork Meganob with Kombi Shoota-Skorcha 1 Fig Clampack July 14-Jul-12 21-Jul-12 - $22.25 $30.00
    Ork Meganob with Kombi Shoota-Rokkit Launcha 1 Fig Clampack July 14-Jul-12 21-Jul-12 - $22.25 $30.00
    Ork Kommandos 5 Fig Box July 14-Jul-12 21-Jul-12 - $45.00 $55.00
    Boss Snikrot 1 Fig Box July 14-Jul-12 21-Jul-12 - $22.25 $30.00
    Ork Flash Git with Targeting Squig 1 Fig Clampack July 14-Jul-12 21-Jul-12 - $19.25 $25.00
    Ork Big Gun (Zzap Gun) 3 Fig Clampack July 14-Jul-12 21-Jul-12 - $29.75 $35.75
    Ork Nob with Waaagh! Banner 1 Fig Clampack July 14-Jul-12 21-Jul-12 - $22.25 $30.00
    Mad Dok Grotsnik 1 Fi Clampack July 14-Jul-12 21-Jul-12 - $19.25 $25.00
    Kaptin Badrukk 1 Fig Box July 14-Jul-12 21-Jul-12 - $22.25 $30.00
    Ork Big Gun (Kannon) 3 Fig Clampack July 14-Jul-12 21-Jul-12 - $29.75 $35.75
    Thieving Grots 6 Fig Clampack July 14-Jul-12 21-Jul-12 - $19.75 $23.75
    Ork Big Gun (Lobba) 3 Fig Clampack July 14-Jul-12 21-Jul-12 - $29.75 $35.75
    Vindicare Assassin with Exitus Rifle 1 Fig Clampack July 14-Jul-12 21-Jul-12 - $16.00 $19.75
    Arco-flagellants 3 Fig Clampack
    Vindicare Assassin with Exitus Pistol
    Callidus Assassin 1
    Eversor Assassin with Executioner Pistol
    Death Cult Assassins
    Jokaero Weaponsmith
    Crusaders 2 Fig Clampack
    Grey Knights Brother Captain 1 Fig Clampack
    Inquisitor with Inferno Pistol & Power Sword
    Inquisitor with Power Sword and Bolt Pistol
    Grey Knight with Psycannon
    Grey Knight Brotherhood Champion
    Dark Eldar Razorwing Flock
    Dark Eldar Prisoners
    Dark Eldar Beastmaster
    Dark Eldar Clawed Fiend
    Drazhar 1 Fig Clampack
  • Mit der Überschrift ++ Psionische Interferenz geortet ++ könnte es vllt auch auf die angeblichen Psikarten hindeuten...
